SanDisc Secure Access Vault
Buongiorno, il mio problema è che ho perso la Usb 8 GB vecchia di qualche anno (dove però avevo fatto l’aggiornamento del software al 2.0) e dopo aver comprato una nuova Cruzer Pop 16 GB, non riesco ad aprire l’archivio Secure Access Valut che avevo precedentemente salvato nel pc di casa.
Potete aiutarmi?
Grazie, Mauro
Would be nice if this was written in English. I tried good translate but it did a poor job in translating.
Sorry, but I do not speak English!
Hello, the problem is that I have on my desktop pc, saving the “Secure Access Vault” of an old 8 GB USB that I lost (where I did the software update to v2.0 SecureAccess).
So, I bought a new 16 GB Cruzer Pop, I did the software update to v2.0 SecureAccess, but I can not open the files saved in the “Secure Access Demo Board” of my pc.
Can you help?
Thank you, Mauro
:smiley:    Hi Toscocasa,
Dear member of SanDisk Community, welcome.
Please, do not grieve, friend:
Remember that, there are two softwares, one for Windows and one for Mac.
And SanDisk SecureAccess Software you must install in the UFD.
Compatibility:
SanDisk SecureAccess software is supported by Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.5 and up. Use with a Mac requires other software download.
The latest version of SanDiskSecureAccessV2, you can download (free) from here:
         http://kb.sandisk.com/app/answers/detail/a_id/2399
         http://kb.sandisk.com/app/answers/detail/a_id/2413
1-     Download on the UFD, to SanDiskSecureAccessV2_win, (if you have PC).
Beware 1: If you figure thus: SanDiskSecureAccessV2_win .exe , go Tools/Folder Options/tab/View and tick: hide file extensions, by the way, you notice, that are also branded the choices: hide files protected, and do not show hidden files and folders.
2-     Then, you install the program, password, etc. And you will have two files:
2.1-  SanDiskSecureAccessV2_ win , (the application).
2.2-   SanDiskSecureAccess Vault (which is the folder that contains the encrypted files).
2.3-   If you lose or delete to SanDiskSecureAccessV2_win (2.1), there is no problem, as other download, and ready.
2.4-   But if you lose or delete a SanDiskSecureAccess Vault (2.2), missed all content (maybe with Recuva can recover).
2.5-   If you can change the name, the application (2.1).
2.6-   Do not you can change the name, the folder/Vault (2.2), because the name is generated by the application (2.1), and if you change it, the application will not open, and will generate a new Vault.
2.7-   I f you can move on, too, to the application (2.1), a any folder.
2.8-   You can not move the folder/Vault (2.2). You should leave it in the root of the UFD, because that is where the going “find” the application (2.1).
Beware 2: Always make, backup content, copy the Vault, clone the UFD, etc., and save everything in “safe place”.
Luck, and then you tell us, what happened, please.
Regards, Alfred.                                (Google translated)
:smiley:   Hola Toscocasa,
Estimado miembro de la Comunidad SanDisk, bienvenido.
Por favor, no te aflijas, amigo:
Recuerda que hay dos softwares, uno para PC y uno para  Mac.
Y que SanDisk SecureAccess Software, debe ser instalado en la UFD.
Compatibilidad:
SanDisk SecureAccess softwarees  es soportado por Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.5 and up. El uso en una Mac requiere descargar otro software.
Está la última versión, de SanDiskSecureAccessV2, que puedes descargar (free) de acá:
1-     Descargar en la UFD, a SanDiskSecureAccessV2_ win , (si tienes PC).
Cuidado 1: Si te figura así: SanDiskSecureAccessV2_win .exe , ir a Herramientas/Opciones de carpeta/pestaña/Ver y tildar: ocultar extenciones de archivo, de paso, te fijas que también estén tildadas, las opciones: ocultar archivos protegidos del sistema, y no mostrar archivos y carpetas ocultas.
2-     Entonces, instalas el programa, contraseña, etc. Y tendrás dos archivos:
2.1-   SanDiskSecureAccessV2 _win , (que es la aplicación).
2.2-   SanDiskSecureAccess Vault , (que es la carpeta que contiene los archivos encriptados).
2.3-   Si pierdes o borras, a SanDiskSecureAccessV2_win (2.1), no hay problema, pues descargas otro, y listo.
2.4-   Pero si pierdes o borras a SanDiskSecureAccess Vault (2.2), perdiste todo el contenido (quizás la puedas recuperar con Recuva).
2.5-   Si, le puedes cambiar el nombre, a la aplicación (2.1).
2.6-   No le puedes cambiar el nombre, a la carpeta/Vault (2.2), porque el nombre, es generado por la aplicación (2.1), y si lo cambias, la aplicación (2.1), no lo va a abrir, y va a generar otro Vault nuevo.
2.7-   Si puedes cambiar de lugar, también, a la aplicación (2.1), a cualquier carpeta.
2.8-   No puedes cambiar de lugar, a la carpeta/Vault (2.2). Debes dejarla en la raíz de la UFD, porque ahí es, dónde la va a ir “a buscar”, la aplicación (2.1).
Cuidado 2: Hacer siempre, backup del contenido, copiar el Vault, clonar a la UFD, etc., y guardar todo, en “lugar seguro”.
Luck, y luego nos cuentas, qué pasó, por favor.
Saludos, Alfred.
:smiley:   Ciao Toscoca,
Gentile membro della SanDisk Comunità, benvenuto.
Si prega di non afflitti, amico:
Ricordate che ci sono due software, uno per PC e uno per Mac.
E SanDisk SecureAccess software, deve essere installato sul flash USB.
Compatibilità:
Softwarees SanDisk SecureAccess è supportato da Windows XP, Windows Vista, Windows 7, Windows 8 e Mac OS 10.5 e superiori. Utilizzando un software per Mac richiede scarica un altro.
E 'l’ultima versione di SanDiskSecureAccessV2, è possibile scaricare (gratuitamente) da qui:
1-      Scaricare l’unità flash USB a SanDiskSecureAccessV2_win, (se si dispone di PC).
Attenzione 1: Se si figura così: SanDiskSecureAccessV2_win.exe, andare su Strumenti / Opzioni cartella / scheda / Vista  e zecche: nascondere le estensioni dei file, tra l’altro, si nota che sono anche di marca, per mangiare: nascondere i file di sistema protetti, e non mostra cartelle e file nascosti.
2-      Poi, si installa il programma, password, ecc. E avrete due file:
2.1-   SanDiskSecureAccessV2_win, (l’applicazione).
2.2-   SanDiskSecureAccess Vault (che è la cartella che contiene i file crittografati).
2.3-  Se si perde o si eliminano a SanDiskSecureAccessV2_win (2.1), non c’è nessun problema, come un altro shock, e pronto.
2.4-   Ma se si perde o si elimina un SanDiskSecureAccess Vault (2.2), perse tutti i contenuti (magari con Recuva può recuperare).
2.5-   Se è possibile modificare il nome, l’applicazione (2.1).
2.6-   Non è possibile modificare il nome, la cartella / Vault (2.2), perché il nome è generato dall’applicazione (2.1), e se si cambia, l’applicazione (2.1), ma non si apre, e che per generare un nuovo Vault.
2.7-   Se si può cambiare il tuo posto, troppo, per l’applicazione (2.1) in una cartella qualsiasi.
2.8-   È possibile modificare la posizione, la cartella / Vault (2.2). Si dovrebbe lasciare nella root dell’unità flash USB, perché è lì che il gioco si “trova” l’applicazione (2.1).
Attenzione 2: Effettuare sempre il backup del contenuto, copiare il Vault, clonare il UFD, ecc, e salvare tutto in “luogo sicuro”…
Luck, e poi ci racconti cosa è successo, per favore.
Saluti, Alfred.                                     (Google translated)
Compatibility:
Compatibilidad:
Saludos, Alfred.
Compatibilità:
2.8-   Non è possibile modificare la posizione, la cartella / Vault (2.2). Si dovrebbe lasciare nella root dell’unità flash USB, perché è lì che il gioco si “trova” l’applicazione (2.1).
Compatibility:
Compatibilidad:
Saludos, Alfred.
:smiley:  Ciao Toscocasa,
Compatibilità:
