Well, I posted the previous after downloading the accursed MP3Tag and not being able to figure out the first thing to do with it. I haven’t deleted it immediately like I did Media Monkey, because perhaps with adequate sleep and more patience and determination, I will master it one day.
In the mean time, my problem arose when I borrowed MP3 disks from the library. They are audio books which, obviously, it becomes crucial that they play in a certain order. I dropped and dragged the files directly from the D drive into four separate folders for each book that I had created in the internal memory under the audiobooks folder, with my vista powered pc. Looking at it there with my pc, there are my books, each in their individual folders. However, when I went to listen to them in the audiobook category, they were all grouped in one folder named unknown by the clip+. It played the first 9 files in order, then started in on another book.
This is what led me to desparately search the web for an EASY fix. If I ever concieve that these ID3 isssues are understandable to me, I will return to this post and endeavor to share my understanding in a way that will help idiots like myself. Wait, I don’t want to offend the future frustrated solution surfer. I mean to say a person who is only used to using Windows Media Player to sync things with out any tricky tagging. I’ve used the advanced tagging system in WMP and it seems to just corrupt the files and freeze the player. Similarly, doing a simple sync with WMP can wind up mixing the tracks up, and it’s BOOKS I listen to. So, if there is something called ID3 tagging for dummies, point me to it.
I also feel I should point out, if anyone has read through this excessively wordy post, that once your book is in a playlist, you had better not navigate away from it with out first making a note of your place, because unlike books that end up playing rightly from the audiobook tab, the playlist won’t remember where you were before you started listening to music or another book.
Hmmm, have I made you think twice about asking what “exactly” is the issue?
I do appreciate all efforts to help, I just hate feeling stupid when I can’t make heads or tails of the solution. I don’t blame you. I struggle through life as best I can and have other things frustrating me as well, so it’s all on me. I just imagine I can’t be entirely unique which is why I chimed in on this post, to hopefully offer an easy solution for someone like me.
This is my second clip and they are super great for listening to audiobooks. Most of the time I download from libray2go and have no troubles whatsoever. I used to carpool with someone and would regularly listen to two books simultaneously with no trouble whatsoever. There are 6 different people I work with who have clips and love them to death. One obsessively collects them and is tickled to be the first one inour group with a clip zip! So I’m not a hater, just having the occasional hiccup that makes me want to pull my hair out.
The End.
