Restoration of unsaved voice record
Hello everybody!
In my last undergraduate class I had attended, when I was saving my two hours I had recorded the lecturer (with his permission of course) - in the “Save recording?” menu I mistakely pressed the button when the “No” was highlighted and picked up the “No” instead of “Yes” so the record was not saved. I didn’t tried to record since then.
Is there any way to restore the lost data of the unsaved record? Please
Very important.
Please, Very critical. Thanks.
Thank very much dear.
I will report to you if anything is going on
JUst to check on this Toto, were you able to recover the files using Recuva?
It’s not working for me :frowning:
What isn’t working? :confounded:
If you want help, you need to at least say what your problem is. :wink:
I have the same problem!!! could you recover your file?
I answered you in your earlier post. No need to post the same question in a different board. Especially since you said you have an e250; this board is for the Clip & Clip+ and this thread is 2 years old. :wink:
