I have a WD Passport drive model WDBYxxxxxx bought 2014. I will like to remove password protection and uninstal all WD smartware and other WD programs. I will like to turn this drive into a standard HD drive so I can plug it into any computer. I looked into the WD Security program telling me to:
Type password in box
select Remove Security option
Click UpdateSecurity Settings
The problem is I don’t have a box or button labeled Remove Security
I only have boxes to place the password, then verify the password,then password hint and last
Save Security Settings
I already updated the WD Security software so it is current. I also don’t have any options under the WD Smartware either. Please help
Thank you
Prime 27
