Smartware doesn’t show the unlocked drive in the settings tab so I can’t select the security option to remove the password. I can unlock the drive and see all the files.
The drive is displayed on the home tab. Is there some software that I haven’t installed yet that I need to?
I have read the manual but it is no help here as it assumes the drive is displayed in the settings tab. The computer the WD is connected to is displayed under settings but not the WD.
I want to remove the password so it doesnt stop my EaseUS automated backup from starting.
I will give it a try unless there are some other suggestions. I dont want to have to wipe the backups that have already been done - which will happen with a reformat!
These are the steps but I didn’t repeat to confirm as I was working on someone else’s computer.
Connected WD drive but didn’t unlock
Started Smartware
In the Home tab clicked on WD drive
Unlocked
Settings tab
Drive settings
Security
then I was able to remove the password.
I suspect not being able to display the Drive Settings originally was due to unlocking the drive before starting up Smartware. Maybe this is some type of security feature or just how it works but it is not highlighted anywhere NOT to unlock the drive before going into Smartware to remove password.
Of course it doesn’t say to unlock it either but you are prompted quite a few times along the way.
Hopefully this is useful for someone in the future.
