I’m getting a message on my Clip “Synchronize to continue your music subscription.” when I try to open up an eAudiobook.
I downloaded the file from the library’s website and it came down as an .wma extension.
I downloaded it to my pc and copied it with Windows Explorer to the audiobooks directory on the Clip. This did not work.
I then tried downloading directly to the Clip. I got the same message. I tried bringing it down to the PC, then opening it up with Windows MediaPlayer and it started up on the PC. I then used the MediaCenter “copy to device” feature to move it to the Clip. This copied it over but I still get that message and the book won’t play.
Can anyone help? I’m probably missing something really simple.
I just got my Sansa Cliip this week and this is the 1st time I’m trying to listen to a book. So far, the player has been working great.
thanks.
