The following is what I just posted to Sandisk support as a support request. Anyone here have any advice? I’ve tried reformatting the card with the SD Association tool with no luck.
I bought an 8GB Sansa Clip+, and also a 16GB Samsung MicroSD card slot. If I plug the card in and then connect the Clip+ to the computer, the computer tells me the USD drive is unformatted. I took the card out of the Clip+ and plugged it into a card reader, where it works fine. So, I copied some music onto the card and put the card into the Clip+. The Clip+ could then see the music. However, when I plugged the Clip+ back into the computer the USD drive still shows as unformatted. So, I cannot copy music onto the Clip+ the easy way. Also, if I connect to the computer and then unplug, typically the SD card is no longer readable in the Clip+. If I eject the card and re-insert it then the card is readable again. I am on the latest firmware version, 01.02.16P
I know poster’s have said they’ve formatted the microSD card, but have you used the SD Formatter 3.1 program to format the card? My Sandisk 16GB card had issues with my Clip+ until I formatted with with the SD Formatter program.
Also keep in mind that once formated you might have to create a folder structure (below) on the microSD card for the Clip+ to properly read the files.
Thank you very much for the provided information. I would like to inform you that we are currently looking into the particular issue; we are hoping this will be fixed with the next released firmware update for your player.
Sounds a little like a standard “fob off” response to me, but maybe I’m just too cynical.
In response to other suggestions, I have formatted with the SD association as my initial post said.
Folder layout on the device seems to be not pertinent, as the player will happily read songs from anywhere on the MSC partition when playing songs, but doesn’t whenever you connect it to a PC.
