Hi
I just got myself a fuse+ to try out and am having a lot of problems getting , FLAC files to work. I have updarted to the latest firmware.
I have read around the issue and know the Fuse does not support twenty four bit. The music I’m transferring is ripped using EAC and in some cases Media Monkey and is sixteen bit. I checked this using the codec properties option in VLC
If i set the USB mode to auto on the device then anything on my MM synch list gets transferred and appears on the device but i get an unsupported file type error when trying to playback the FLAC files.
If i set the USB mode to MSC then not all of the music appears on the device after transferring it using MM (it shows as being copied by MM if you watch the progress bar) but what does transfer does playback
I am leaning towards the issue being tagging related but am not sure how to figure this out.
If I could post two files, one that transferrs and one that does not, is there someone who might be able to help figure this out please?
Thanks in advance
Chris
