Problem with Sandisk Cruzer blade pendrive
Dear Sir/Madam
I have a sandisk cruzer blade 4gb pendrive.Now it is showing write protected error. By this error nothing can be deleted from pendrive and can not copy anything.what is solution for this.Kindly tell me immediately .Thanks
Return it immediately.
If the files on it are important you should copy them to your hard drive before returning it
If I dont have the means of returning the pendrive what do I do? Please help before I go crazy.
“If I dont have the means of returning the pendrive what do I do?”
Copy the files on the pendrive to your pc’s hard drive, buy another pendrive, copy the files from your pc’s hard drive to the new pendrive.
If you were able to obtain the drive in the 1st place (bought and picked up at retail strore, ordered off of internet, etc.), there should be be a way to return it.
