PLEASE READ**** INFO ON FORMATING A BLANK MicroSD CARD/CHIP in Windows Vista/XP
If you have just got a new Blank Card/Chip (Mircro SD) and want to place Mp3’s on the card, Windows may ask you to format the Card/Chip MAKE SURE YOU PICK FAT-32. NOT NTFS
no player will read the chip if you have formated the Card/Chip to NTFS…
Many of us wish this was an issue with the Clip–the Clip doesn’t have a microSD slot.
But thanks for the info. regardless–
You are welcome… If I find any info that may be helpful, I sure will let you know.
I have tried to format the micro chip via XP and when plugged into the computer it always freezes "my computer " window so that I cannot format it. Once I pull out the chip the computer unfreezes and acts normal. This happens on my both my laptop and another xp desktop that I have. do you have any suggestions?
