Can somebody help me out? Spent lot of a time creating some playlists in Media Monkey. Then exported them to my Fuze (8gb). But now it seems the Fuze wont recognize them. I choose for playlists in the music option and then click on the name. I wait a lot of time, actually thought it froze, but nothing happens!
I’ve never tried using MediaMonkey for playlists. For the heck of it try the free Playlist Creator 3. Point it at the directory or files and tell it what to call the playlist and where to put it and click on create. Do that for just one album and see if it works for you. I havent played with MMs playlist creation since it seems too counter-intuitive to me (I’m sure it’s just me tho)
Thanks for the replies. I think I saw what I was doing wrong. I wasn’t selecting files from the Fuze itself, but from my computer. I guess that was the problem.
Syncing pla playlists in MTP is easy with MM (if you sync rather than drag and drop), you just add the playlists to the sync list in the options for the player. If you don’t use MTP and/or don’t sync… can’t help, sorry.
