Playing .AVI file
I have taken a DVD and ripped it to an .AVI file. The player will not take the file. “something is outside the players peremitters…”
The file is not too large.
I created the file without the sansa media converter. I tried running the file through the sansa media converter (overnight) and it appears to not have completed the task as the file is not on the player.
I bought the FUZE specifically because I thought it could play my movie file.
I am very frustrated.
video4fuze converter
jup you have to convert the files, the fuze wont play standard XviD/DivX 640x480 files, it will play 224x176 DivX 5 files, so you have to use Video4fuze or Sansa Media Converter to convert them
and the video future is a bonus future, its limited, the Fuze is the best mp3 player when it comes supporting open free audio formats like FLAC (lossless) and Ogg Vorbis (lossy)
I downloaded the video4fuze converter.
When attempting to convert the file I get “error 2” can’t locate the file ???
What USB setting must the fuze be in?
The Sansa media converter starts the conversion process but gets hung up at 50% and never completes the process.
I used Handshake to convert the VOB file to AVI. There are various settings for the file output in addition to .AVI. I have no clue what they mean. Perhaps my problem lies there somehow.
Any more thoughts?
224x176 DivX 5 files       ???
I do not know what you mean. I am understanding the only video I can play on the fuze is a file run through the Sansa media converter or video4fuze.
Try this
  1. Go to C:\Program Files\video4fuze\avimuxgui\
  2. Right click on AVIMux_GUI.exe and go to properties > compatibility > Run this program in compatibility mode for Windows XP (Service Pack 2) and click OK
  3. now download mplayer from http://sourceforge.net/projects/mplayer-win32/files/MPlayer%20and%20MEncoder/revision%2030075/MPlayer-rtm-svn-30075.7z/download
  4. copy the files in the mplayer.7z to C:\Program Files\video4fuze and overwrite the current files
  5. go into Video4Fuze Advanced > preferences and change the path to C:\Program Files\video4fuze\mencoder.exe on both passes
  6. then OK and now try encode a file :)
you might need 7-zip to open .7z files
http://www.7-zip.org/download.html
Message Edited by wiak on 12-29-2009 02:10 PM
Message Edited by wiak on 12-29-2009 02:11 PM
Message Edited by wiak on 12-29-2009 02:19 PM
