password protection cruzer edge 8gb
I’m lost. Installed the software. I am asked for password, I give it, I open my Vault, BUT SO WHAT?? Anytime i want, either in My Computer or in, for instance, ACDSEE I can view all my files without the necessity of the password. Obviously I’, not getting something. I tried to uninstall Manager and start over, but I can’t. I seem to have a useless product.
the only files that will be protected by secure access are the files you actually store in the application. here is a link to the user guide that will probably help you out.
http://mp3support.sandisk.com/downloads/um/secureaccess-userguide.pdf
Hey - I am having the exact same issue. I too am missing something here.
Did you find a solution to the problem of password protecting your SanDisk Cruzer Edge USD flash drive?
Jonny
