Howdy! new to the ssd Hard Drive scene, is there a way to disable my password? I don’t have any secrets to hide using this hard drive I just want to plug it in and be able to look at my files. Also, does it hurt to leave it plugged in to my computer at all times? I do T-shirt type of work and make a lot of revisions.
Thanks
Mike
did you use the secure access software to enable the password or did you use another encryption software with the drive?
if you used the simple secure access software then you can just format the drive and use it without it to store your data inside.
no need to format the drive. just delete secure access and the secure access vault folder. Then just use it as any other removable drive.
Thank you for posting this problem & for the response. Grateful to be able to disable the password requirement!
