Pairing Bluetooth on my Sandisk Clip Sport
@willydu wrote:
I never had anything like that!? a volume popup? even on my old Clip Sport 8GB nothing like that. What language and region you put the player in? I set mine as the old one too language: English, and region to: North America
I’m not in America but c’mon I want the full volume experience
 :wink:
I know if you put it on other regions you get some volume limitations. Maybe that is some sort of your problem?
I’m using Swedish as system language and the region is EU. I have now tested to change to English and that didn’t solved this. I tested with factory reset and then North American and that seems to solve this. Thanks a lot :).
will the powerbeats pro work with my clip sport plus?  i was thinking of getting them and i’m not sure if they will work.
i have jlab jbuds air and i cant seem to connect to my mp3 player can some one help
Unfortunately I can only add to this dilemma. I have a brand new pair of Jaybird Vista earbuds and they do not detect them at all. In fact they don’t detect any Bluetooth products that I have. Very, very dissapointing. Unless I can find a quick solution, I’ll have to move them on, but given the Bluetooth issue, it appears even that will be difficult…
I thought I had the same problem: Several BT devices I tried were not discovered by the Sansa player (some were) even though I could pair them with no problem to my phone (also after I first unpaired it). I even got a replacement thinking that the bluetooth module in my Sansa was faulty. I turns out some devices need putting them manually into pairing mode while some do it automatically (not the same as them trying to connect to one of previously paired devices when switched on). On my earbuds, I had to hold both controls for few seconds. On my hifi, I had to press play after selecting bluetooth input. Note, none of this was necessary to pair with my phone. I guess it is smarter than the Sansa player. I suggest you check your earphones or speaker if there is a specific action you can trigger to put it into pairing mode.
