When I push otpion nothing happens!!!
I can’t give ratings…
I fixed it once by turning it off and on, but now that trick won’t work.
So I reset the thing, and now i cant put the @ symbol in my login.
What should I do? I think I will end up sending it in to get fixed.
I going try the recovery, and I will report back if it works.
… Sansa rocks!
