Nothing happens when I click on sandiscsecureaccessv2_win
I can see that the files still exist in the encrypted vault but nothing happens when I click on the application.
I tried deleting the application and downloading v3 but it said a previous version was being used.
I bought a new stick and moved the encrypted files into the vault with the same password but they stayed encrypted.
Any help would be appreciated.
in that case where you used the previous version 2 to encrypt the files you will need to contact the support to provide you the link to the version 2  so you will be able to restore the encrypted files again
here is the contact link
http://kb.sandisk.com/app/ask/
Hi, are you still interested in recovering your data or you got rid of your Vault and/or USB Stick?
I can help you save it if you are still interested in recovering your data.
