hey guys,
my fuze is not charging no matter where and what computer I plug the adapterinto the usb ports and i wonder if it might be caused by the latest firmware updates?? please help me, i need to get this thing charged and im using windows XP
hey guys,
@sixpapavictor wrote:
hey guys,
my fuze is not charging no matter where and what computer I plug the adapterinto the USB ports and i wonder if it might be caused by the latest firmware updates?? please help me, i need to get this thing charged and im using windows XP
I don’t believe it would be the Firmware update. When you plug the Fuze into the computer does it show that its connected and charging? If you are not getting a connection try eliminating the USB cable and try another if you have one. If you haven’t tried, try pluging into the back ports of your computer if its a desktop computer. I am assuming you leave your computer powered up and that its not going into hibernation. Is your computer a laptop? If nothing works contact Sansa Suport.
Post back with more info, or if you get this fixed tell us what you did , Cheers
Message Edited by niko_sama on 01-31-2009 01:30 AM
It is not a firmware issue or we probably would have heard this by now, The easiest thing to test is to go out ang get yourself a wall adapter so you can plug in to a wall outlet and then hook upi your USB cable and charge the fuze that way. If it wont charge then odds are its a bad cord or your fuze has a bug.
try switching your USB mode from MTP to MSC.
it helped me
Before you go buy a wall adapter, try this, it worked for me.
Do a soft reset, (hold power switch for 20 seconds)
If it turns on, turn it off, and plug the Fuze into a computer.
Hope this works for you.
