Need new firmware for SN750 1TB, 111130WD fluff or newer
I have a WD SN750 1TB Black WDS100T3X0C-00SJG0 with firmware version 102000WD, this firmware is very old from around 2019. Another user with the same exact mode/revision SN750 has a newer firmware 111130WD on their drive. When i use the Dashboard tool to check for a new firmware update it says its already the latest firmware which is not true. I really need a newer firmware version for my SN750 because it has the reset bug when being used with X570 motherboards on both the M.2 slot connect to CPU lanes or PCH lanes. The same SN750 works flawlessly on my LGA3647 Xeon C621 workstation system. Im essentially stuck on the release firmware version and cannot find any of the update files. If someone could help me locate these firmware update files it would be greatly appreciated.
@Jack154 Two like drives may have different firmware as needed by the build process.
It does not mean an update is available or needed for one drive or the other.
Interesting, has there been any firmware updates for the 1TB SN750 WDS100T3X0C-00SJG0 meant to fix things from the original version 102000WD which was released in 2019?
Thank you
