I just did a manual firmware flash of my SN750 1TB NVMe drive using WD Dashboard. My drive has been on firmware version 102000WD, and I just manually flashed 711130WD.
Dashboard now wants me to reboot to finalize the flashing, however, I’ve since discovered this firmware file I flashed (711130WD.fluf) apparently isn’t for my version of drive. My drive is a WDBRPG0010BNC-WR. I hadn’t known there was a different model/version of the same drive (WDS100T3X0C).
So does anyone have a 102000WD firmware file for the SN750? The only firmware files I’ve found are 711130WD and 711250WD, which aren’t the right ones for my drive.
I urgently need to re-flash my current firmware 102000WD to overwrite the wrong firmware that’s awaiting flashing the next time I reboot.
