Hi, I rarely use it but was going through the playlists and songs I have on it when suddenly the graphics went blank and all I have now is a lighted screen and can’t turn it off or doing anything with it. I plugged it in to see if that would do anything but nothing. What’s the problem?? Thanks
First, see if the device has simply frozen. Press and hold the power / menu button for about 20 seconds to reset the device.
Do you know if this is a version 1 e260?
Bob ![]()
I did more research and found an older post that mentioned holding down the power button for 30sec. which I did and it turned off and then was fine. Not sure why it froze but all is okay now.
Thanks!
Bob gave you the answer here, yet you ‘did more research’ and found the exact same advice somewhere else?
Amazing. It’s behaviour and attitudes like this that provide a real incentive for one to help others out around here. ![]()
Glad you got it working but . . . Bob gave you the answer here, yet you ‘did more research’ and found the exact same advice in an older post somewhere?
Unbelievable. It’s behavior and attitudes like this that provide a real incentive for one to help others out around here. ![]()
