Hey all… I’m hoping you can help me here…
Last night, I plugged my Sansa 1GB Clip into my iMac. It mounted correctly and everything was ok. Then, I opened Parallels (Windows XP Emulator for Mac) and when Windows was installing the drivers for the Sansa, it locked up and the screen on the Sansa froze… I let it sit like that for quite awhile (over 30 mins) and nothing happened so I decided to unplug it from the data cable… what a mistake that was!!!
Now, the Sansa won’t fully “boot” up - It turns on and flashes the logo and then freezes up and won’t go any further… Also, when I connect it to my PC (not my Mac, an actual XP box), it is not recognized by windows. Instead, I get a message that a USB device attached to this computer has failed…
During the course of troubleshooting the device, I was successful in getting it to boot up in MSC mode. My system now recognizes the Clip and I am able to get into it via My Computer. I can see the system files and folders, etc. (even though all my music appears to be gone) but that’s about as far as I can get with it.
I have downloaded the firmware updater and installed it. When I boot the device in MSC mode, the updater recognizes it, downloads the new firmware (01.01.20), and installs it. It then prompts me to unplug the device to finish the update but when I do, the screen on the Sansa switches over to “Firmware update in progress” and sits there eternally…
I have also manually downloaded the firmware update from this website and copied the file to the root of the device as instructed, however the same thing happens as soon as I unplug it…
I have let it sit at the firmware updating screen for a very long time just to be sure it’s not just a slow process. In fact. I let it sit at that screen overnight and when I got up this morning, it was still at the screen…
I just don’t know what else to do or try. Is my Clip shot? Is there a way to restore it at all?
Any advise would be most appreciated!!
Thanks in advance…
