Hi, even after a solft reset then press again, pug in, no react !!!
What can i do ?
What can i do ?
Can u state the exact problem with ur ClipZip?
is it not turning on after u charged it for around 3 hrs?
Did u reset the player?(like hold the power button for 30secs). then switch it on.?
Just Nothing, black screen !, as i said i’ve tried soft reset, charging all night, not even a icon while charging, Nothing…
You might try holding the on button down for as much as a minute, and leaving the player to charge for a day or 2. Although I do wonder if this is a charging circuit/power issue.
If all else fails, you’re covered by the SanDisk 1-year (or more) warranty, and can contact SanDisk Customer service for a replacement.
If Reset doesn’t work and no icon shows up while charging and u said u charged the whole night,
Then i guess ur player must be faulty.
Contact sandisk Support for replacement if ur player is still under warranty.
Support said it was a real problem, by chance amazon give me a refund (after 6 months !) , i just buy new one, hope this one will not faill after few months…
Great to hear–good for you!
