My pendrive not working
Pen drive not working
I recommend that buy new one, but if in case its important for you than ensure proper physical connection, try it on another computer, and check the Device Manager (on Windows) or Disk Utility (on macOS) for any issues.
Before going to buy a new pen drive, you should do some manual fixes to fix the error of the Pen drive. You can update the USB driver, reinstall the disk driver, recover USB data, change the USB drive letters, and format the USB to reset its file system.
You may need a computer to fix such issues and you can easily do some with cmd.
There are several ways to fix a pen drive not detected issue in your system. You can fix any issue by checking if the pen drive is listed in disk management, creating a new volume, changing the drive letter, and updating or reinstalling the USB driver.
Check out this article for a detailed solution, How to Fix Pendrive not working? | Stellar
Hi @POORANMEENA8 ,
If your SanDisk pen drive isn’t working, try these steps: check the USB port, update drivers, format the drive if accessible, and use Disk Management to check its status. For further assistance, visit [SanDisk Support].
https://www.sandisk.com/about/contact
Hey OP, can you give a bit more detail about what’s going on? Like, is Windows not recognizing it or are you getting any error messages? That’ll make it easier to figure out what’s wrong.
If you’re worried about losing your data, you could try a free recovery tool first. And if it’s still under warranty, maybe just get a replacement.
First, check out the USB drive in Disk Management - right-click the Start button > select ‘Disk Management’ from the menu.
Locate your USB drive in the lower panel and see if it has a drive letter (e.g., F: or G:). If it does not have a letter, right-click on it and select ‘Change Drive Letter and Paths’ to add a new letter. If you cannot find the USB drive in the list of disks, try these steps such as updating the USB driver on your PC, checking for errors on the SSD using the Windows utility CHKDSK ( This related blog is useful for you: Hard Drives Not Showing up or Working? One-stop Guide to Fix )
