If your pendrive isn’t working, it could be due to corrupted drivers, file system errors, or a faulty USB port. Try updating or reinstalling USB drivers, running a repair tool like CHKDSK, or using a different port or computer. These steps usually fix most common issues and help recover your files safely. For a complete step-by-step guide,
First, check if the USB drive is visible in Disk Management. If it is visible in Disk Management but not in File Explorer, you can try the following methods:
Assign a new drive letter to the USB drive, such as H:
