my micro sd suddly not working only howing on device manager i can't able to format also
my micro sd suddly not working only howing on device manager i can’t able to format also
Hi @akashkannan
(Get Support for Your SSDs and Flash Products | SanDisk)
(Contact Support | SanDisk)
It would be very frustrating to see this kind of issue. Such problem can only be fixed by formatting only and that too is not accissible. Cehck for any physical errors and damages on the card or check this video.
No worries. There are some basic solutions you can try. You can try some basic solutions, such as updating the drivers and using CHKDSK to fix logical errors on the SD card.
Read this: Top 6 Ways to Fix SD Card Won't Format on Windows 11/10/8/7
If your SD card is corrupted, it could be a bit tricky. I suggest getting a new one or having it repaired.
