I have 6 MP4 movies on my ixpand but when I play them they stop/freeze after < 1 minute. I’ve tried all 6 and have the same issue when using my ipad
Movies work fine when the ixpand is inserted in the PC
what codec is used in the MP4 container? Also sandisk has a dedicated video palyback app called TopReel. have you tried playing the videos in that app?
Here’s what I did to fix it:
First, make sure you have enough space on your iPad for the movies to play smoothly.
Try updating the iXpand firmware and also check for any iPad software updates.
If the issue persists, consider converting the MP4 movies to a slightly lower resolution. Sometimes that helps with playback glitches.
Also, check if there’s any specific app on your iPad causing the problem. Try playing the movies with a different video player app.
Also, you can try downloading the video at https://www.movavi.com/ and play it there. Good luck!
Here are some possible solutions to the issue you are having with your iXpand:
I hope it helps!
