MP3 audio files play too fast
I have been using my Clip to listen to podcasts and audio books for a couple of years. All of a sudden all of my readers are chipmunks! The files sound fine on my PC (windows 7). I am updated to 2.01.35 but the problem did not seem to start when I did the firmware update.
BTW my music files seem fine
If you haven’t already, first thing I’d check is to look under Settings->Audiobook Options->Speed and make sure it says “Normal”, not Fast.
Thanks for the help but I did not see an audio book setting
The reset did the trick. I am not sure why they have a play it fast option…I am just glad it is turned off.
