I just discovered a problem with the Sansa Clip (4GB), but whether it is due to firmware version 1.01.32F or the device itself.
In fact, I discovered that it reads the files (I only tested MP3 CBR, VBR, on different frequencies) slightly faster than normal …
It really is very light but quite noticeable on some fast music.
To be sure, I started at the same time on 3 different players (Winamp, Ipod, Creative), the same mp3 and it is only about ten seconds, the difference becomes obvious … The Sansa Clip takes the lead on the others !!!
Is it that others can confirm this by testing ?
Someone would have an answer to this problem or it would be the firmware that needs to be corrected ?
Should I contact technical support ?
Thank you for your responses.
PS : I hope the translation wasn’t too wrong, because I’m not English
