microSD suddenly unable to read
Hi all,
I have a microSD which works  fine, until yesterday, my phone pop-up a
msg ‘memory full, please delete your files’.
Besides, i cant read or write any files on the phone to the memory card.
While i’m using a card reader to read the card from computer, it says the card is not formatted…
Any suggestion for this issue?
Thanks~
Since it is still being recognized by the computer probably Error-Checking can still fix the problem.
If it doesn’t work then unfortunately you would have to format the card already.
@Jamieson - I am also facing a similar problem. I bought a new microSD 2GB card on JAN’2010 for my Nokia N79 mobile device. Till yesterday it was working fine suddenly it is asking for a password when I try to access it.
I have also tried using it with my card reader in PC. It is showing "Insert New Dist (I)"
What may the problem does it mean it is gone? do I have to claim for warranty? and I also have some important personal data in it.
I would be very greatfull to you if you help me in fixing it.
Regards,
Resolver
Sounds like a bad card already. Call their tech support for a possible RMA.
