MicroSD Card Stuck Issue
yestrday i inserted my 16GB card to see if it works…
after i removed it… the Player stucks every fews seconds even in the the music.
when i insert the Card the player running fine…
 i dont want MicroSD inside the player all the time
how can i fix this issue?
Edit - i tried Sansa Updates 5 and 12 without the Card and i get Scsi sense code: Device reported an undefined sense code…
i can only reflash with the card inside
Thank you
Message Edited by TDMaster on 09-09-2009 08:10 PM
Format the MP3 player while the card is inserted, make sure you have backup of the songs both your mp3 player memory and micro sd because it will delete everything. :wink:
i tried to format the player with both firmware but still same problem…
and i also tried format the Internal/External Memory from inside the phone same problem…
Did you format your Internal memory in the computer? try formatting it on force MSC and format it under disk management;
Press and hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
Firmware Update and follow Method 2;
Error;
Hope this helps  :wink:
