Micro Sd and napster compatibility
Hi guys,
          Just wondering if I will be able to transfer my napster music to my sd card, or am I just limited to storing it on the internal memory card?
Cheers
I see no reason why not.  If they’re DRM protected files, you’ll have to put them in Windows Media Player, hook your Sansa up in MTP mode, and just click “Next Device” in the top right to get to your card.  If they’re not protected, however, you can just drag them into the music folder of your card, as long as its a compatible format, which it almost certainly will be.
