Hi - I just got the latest firmware & my clip seems to be stuck in radio mode. I think it is just wearing out? This is the 2nd one I’ve had after a similar issue with the first. They sent me a refurbished one & it’s lasted 2-3 years. Anything I can do about it? Do they usually wear out? Thanks!!
Stuck? Did you do the firmware update properly? Try downloading the firmware again and manually install it on the player.
The players do wear out after a while. The battery could wear out, buttons could wear out, or circuitry could wear out. I guess these players are designed to last around 2,000-4,000 hours of use.
OK thank you.
