Hi there
How can I setup the volume LEVEL? IN FULL VOLUME IS STILL TO LOW
Hi there
I would update to the latest firmware if you already haven’t. I would also check to see if you haven’t set the volume limit to ‘normal’. There is a setting that will allow you to change the volume limit from ‘normal’ to ‘high’
Did you read the 5th sticky post down from the top of the page entitled No More high Setting in Music Volume?
Did you read the 5th sticky post/thread down from the top of the page entitled No More High Setting in Music Volume?
You can substantially increase the volume of Clip+ by tinkrting with the (Custom) settings of the Clip Equalizer – perhaps by boosting the mid tones. Careful – too much volume might lead to distortion.
