has any one figured it out…how to lock and more important…un-lock.
i just got my new one yesterday.so i think i have the new firmware
nope…i have the old firmware.
so how do you lock it
the directions i found does not lock it :((
ok found the how to video on-line
hold play/pause for 3 seconds… to lock
to unlock slide up on vertical line
seems to work so far ![]()
If you update the firmware (which you should do), the LOCK has been switched to the power button , as described in the updated User Manual. Much easier and stright-forward.
This was the 1st thing user’s complained about, and the 1st thing SanDisk fixed with the intial firmware update. ![]()
