I recently purchased a SanDisk Ultra Flair USB 3.0 drive, but I’m having trouble getting it to work on my Windows 10 computer. The drive frequently disconnects and reconnects on its own when I try to transfer files to it, and the transfer speeds are excruciatingly sluggish.
The problems still exist despite my attempts to update the drivers, format the disc, and even try it on a different computer. Do other Windows 10 users who use SanDisk USB devices experience the same issues? Do you know of any effective cures or solutions?
Any advice or assistance would be much valued. I’m grateful.
I’m sorry to hear that you’re experiencing issues with your device on your Windows 10 computer. It sounds frustrating to deal with frequent disconnections and sluggish transfer speeds.
Have you tried changing the USB port you’re using on your computer? Sometimes, certain ports may need to be fixed with specific devices. Also, consider installing Windows 11 using kmsauto. It can also help. Good luck!
