My sandisk ssd Not Working Properly?
Sandisk SSDs are great, but they’re not perfect. Sometimes, you’ll find there are problems with your Sandisk SDD that cause them to stop working. Which is why we’ve written this helpful guide to troubleshooting your Sandisk SSD to find the problem and fix it.
In this post, we’ll go through troubleshooting tips, what questions you need to ask yourself before ruling out the possibility that there’s a problem with your computer as opposed to your Sandisk SDD, and how you can recover from a catastrophic failure in order so that you don’t lose any data.
Hi @rasone,
Check and secure the SATA or NVMe cables, as loose or damaged connections can cause errors. Verify if power management settings are affecting the SSD’s performance and adjust them as needed. Enable TRIM in your operating system to optimize performance, and be aware of temperature-related concerns that could impact the SSD.
