Ok I will give it shot, I have sometime but no IM.
We’ll try it from here, or someone else may be able to help ya out.
1st you need to download the zip file for your player which is found in this thread,
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=718
After downloding it double click on it & extract it
inside will be a m300a.bin flie
Slide the power button to the hold position
plug in your cable & plug it into the usb port on your pc
while holding the center button on your player
Click on start, then My Computer(in XP, not sure about Vista)
Look for your Player in ther list
Double click on the player
Select the extracted m300a.bin file from the other folder
Hold ctrl & press C, this will copy the file
Go to the player’s folder
Hold ctrl & press V, this will paste the m300a.bin file into your player
Disconnect the Sansa Clip and let it restart.
The firmware update will now begin.
Once it finally finishes doing its update, it will boot back up.
And then you are all done,
Hope this helps,
Really Lost
