I know that people who’ve seen me whine about this in the Fuze board are going to groan, but …
If one alters the contents of the Clip+'s internal memory contents, does the Clip+ re-read the contents of the microSDHC card?
OK…you asked for it…G-R-O-A-N :smileyvery-happy:
Seriously, I’ve never seen it be an issue. The read times in all of my players is very short and non-intrusive.
it should be the same with the fuze, add songs by connecting to computer, after you uplug, “refreshing database” will show…
take out the card, use a card reader to add songs, after you insert the card, it should say “refreshing data base”
My guess is…yes.
I’d just like to know if it happens, thanks.
My point is that the Fuze would re-read the contents of the card even if they weren’t changed, but the contents of internal memory were changed.
It doesn’t necessarily have to be the same way with the Clip+, does it? Unless they share the same portion of the firmware that deals with database updates. The Sansa Connect doesn’t do this.
@miikerman wrote:
PP, I don’t know how one would gauge this–perhaps you do. When I’ve added songs to the microSD card and then inserted it back into the Clip+ and turned it on, I get the familiar “Refreshing” screen. Would the player say anything different if ones adds to the internal memory?
OK, I just added a song first, to the internal memory, and second, to the microSD card in the Clip+. Each time when I disconnect, I get the idential screen, “Refreshing your media”. And the same result when I add songs to a removed microSD card and then insert it back into the Clip+ and turn it on.
If you have, say, 10 songs in internal memory, and 2000 songs on the card, you’ll definitely notice the difference. If the Clip+ only re-reads internal memory, “refreshing” will be very quick. If it re-reads both internal memory and the card, it’ll take longer.
Again, the Sansa Connect handles this properly. I’m not sure how. My guess is that there’s some kind of “dirty” bit on the card that can be read to determine whether the card’s contents have actually changed, and then flipped.
I think the best answer for this is to have the option to disable tag browsing, so there is no delay to refresh the database. When someone changes their mind and decides they do want to use tag browsing again, then the player could rebuild the database.
Maybe I’m in the minority, but I’ve never had a problem waiting how ever long it takes to refresh the database. Are our lives that busy that we can’t wait a few minutes to use a device?..Uhhh… I guess judging by the comments; the answer is yes.
I’m not in a rush to do anything; so the wait isn’t problematic to me.
Doesn’t bother me either ![]()
Most likely you guys posted the same thing in my thread in the Fuze board. ![]()
It has to do with the frequency with which I update the internal memory contents; it’s an inconvenience to me, and given that SanDisk themselves said this would be fixed, I figured I’d just ask regarding the Clip+'s behavior.
I’m glad it doesn’t bother you. You may also like the flavor of squash. I don’t.
Message Edited by PromisedPlanet on 09-01-2009 03:47 PM
A feature that is important to you, may not be important to others. That doesn’t make it unimportant. Sandisk has to balance what is possible to what is necessary or even desirable to most consumers.
It just seems a bit sad to me that instead of celebrating the fact that the clip+ is an awesome unit, filled with nifty new features, we are spending so much time concentrating on what it doesn’t do.
I don’t mean to single you out PP, you are far from the only one…
I just want to thank Sandisk for making a great little player and plan to get one soon! (I recently sold my regular clip and am in need of another little companion)
Exactly. One feature that is important to me, but not important to the people who said “I can wait a few minutes”, is whether or not the Clip+ can determine if the expansion card’s contents have not been altered when it refreshes its database.
The Clip+ looks like a great unit, hence my curiousity and a simple question about the firmware.
I’m not “concentrating” on something that the Clip+ doesn’t do, I’m simply trying to figure out what it DOES do. I.E., does it know to not re-read the expansion card’s contents if only the internal memory’s contents have been altered? Just a simple question, which hasn’t been answered yet.
Peace!
Message Edited by PromisedPlanet on 09-01-2009 04:27 PM
Thanks Miikerman. Just curious, what class was your microSDHC card?
Not sure if it was you or someone else in another thread who said it would be a nice firmware feature to turn off database refreshing all together, in case a person intends to only use folder browsing. That’d be mighty cool.
Sorry that the refresh issue is a problem for you. I just ordered a clip+ without reservation. It is about as perfect a player as can be for my needs.
But - my god - no stopwatch?!?
:wink:
Eh, I’ll probably get one … it’s still a great player, and it’s tough to beat the SQ at this price.
Message Edited by PromisedPlanet on 09-02-2009 09:16 AM
@miikerman wrote:
It’s a Kingston Class 4 card.
(I was happy to see that it worked with the Clip+, as I remember, from awhile back, that people had said that Kingston cards did not play well with the Fuze.)
The Kingston cards were ok for audio with the Fuze, just not video. So you should be fine.
"no stopwatch?!? "
If it had a stopwatch and clock, would you then complain that it doesn’t jave a pedometer? If it has a pedometer then would the complaint be that it doesn’t have GPS?
@jk98 wrote:
"no stopwatch?!? "
Err, I was just joking …
It makes sense that they’d have to rebuild the database regardless of which memory the files were added to. They’re probably rebuilding the database each time since it includes files from both places. Doing an update instead of a rebuild might avoid this but might require a more sophisticated database structure and more code in the firmware. Given the low price and small size this seems like a reasonable compromise.
Barry
