Clip Plus
I’m going to open this new thread for discussion about the new Clip Plus (shown on the retail box as Clip+).
Begbie was the first forum member to mention buying the Clip+ and has started a thread to try and get some help with a syncing problem he’s having with it. Rather than hijack his thread with general discussion about the Clip+, I thought it would be better to have a separate thread just for that purpose.
My wife had a confirmed sighting yesterday (August 29) of the 4GB Clip+ in red and blue for $50 at a Best Buy in Florida.
I have a couple of questions I’m hoping can be answered over the next few days or weeks:
Is the USB connection the same mini-USB connection as the 1stGen Clip, or a proprietary connection as with the Fuze?
What is the GB capacity limit on the microSD card that the Clip+ will read?
What is the stated battery life? What is the actual battery life in real-life usage?
I can see this replacing both my 2GB and 4GB 1stGen Clips. Hoping to see some reviews and user comments here in the coming weeks.
Best Buy has Clip+ info up on their web site, though the site still lists the Clip+ as “coming soon”.
This answers a couple of my questions:
Looks like the Clip+ takes the same USB connection as the 1stGen Clip.
Stated battery life is 15 hours.
I’d still like to know if theirs a limit on the microSD card capacity that the Clip+ will read.
The USB is the standard mini-USB connection.  The manual states the Clip+ can handle microSD or microSDHC cards up to 16GB (I have not verified this myself).  The box states “Rechargeable battery lasts up to 15 hours”, I don’t have a feel for what the real world usage is yet.  The manual says that it plays MP3, WMA, Secure WMA, Audiobooks, Ogg Vorbis and FLAC.  Also says it works w/ Rhapsody and a trial subscription is included (I didn’t find any other info about a trial, no card or code).  I’ve not tried any format other than MP3 so far, if I get a chance I’ll rip some CDs to .ogg and see how that goes.  There isn’t anything on the box or manual about it but there is a directory “AUDIBLE” on the Clip+ (the clip shows up as CLIPP when connected).  The other directories are; AUDIOBOOKS (separate from AUDIBLE), MUSIC, PODCASTS, and RECORD.  From the other thread, Miikerman asked,
As to folder view, I guess the question is, can you navigate and plays songs in a folder-view type approach, just like on your computer?  Or does the Clip+ still fall back to using the ID3 tags for selection?
In the folder view the actual file name shows up, it navigates the same way a file browser on the computer does.  dgb52 asked,
Is the headphone jack on the top or bottom and what state did you pick this up in?
The jack is on the upper right side, same place as the original Clip.  I picked mine up in Tennessee, and as BigJohnL mentioned there was a sighting in FL.
Also there was a $5 off coupon for a slotRadio card in the box (you need to buy it at www.slotradio.com). Feel free to ask anything else, if I can answer I will.
A nearby Best Buy in Waxahachie, Texas has 12 of them for $56.99.  I’m getting one later today.
“I’d still like to know if theirs a limit on the microSD card capacity that the Clip+ will read.”
If a player takes a micro SDHC card, then it will take any capacity one. The issue though is what the maximum number of songs the player’s database can accomodate. On the Clip it is just 2,000. On the Fuze it is 8,000(but was 4,000 for a long time before the most recent firmware update). I hope the Clip+ can support at least 8,000 songs.
Now that this is out, why would anyone want a Fuze, asides from folder navigation? :dizzy_face:
"Now that this is out, why would anyone want a Fuze, asides from folder navigation? "
It says in this thread that the Clip+ has folder navigation.
i like the Fuze for its scroll wheel, larger display,  and longer battery life than the Clip.
I dislike the proprietary connector and lack of a built in clip on the Fuze.
Message Edited by JK98 on 08-30-2009 01:00 PM
I think the Clip+ does have folder navigation.  As for why have a Fuze and not this?  I don’t know.  I just know I want one!
Agreed.  The database implementation will likely be the limitation on the capacity.  The portion of the firmware which accesses the microSDHC card should implement the microSDHC specification, and should allow for up to a 32GB microSDHC card.
(> 32GB is microSDXC … http://www.letsgomobile.org/en/4470/sdxc-memory-cards/)
Message Edited by PromisedPlanet on 08-30-2009 02:02 PM
Confirmed that the Clip+ has track info and folder viewing…so to heck with the Fuze!:smileyvery-happy:
( I kid…I had a Fuze for 11 months and was very happy with it…but now, the things I liked better about it are no longer exclusive to it.)
Someone just asked me why I bought a fuze and I can’t remember (seriously).  However, I’m glad I did if only for rockbox.
Can’t wait to get a clip+
The built-in clip on the back appears to have been redesigned too!
The card slot on the Plus is the seller for me, goodbye Gen1 clip! There are several functions desired by people that hopefully will be added in the future. The major missing function of any Clip (IMO) is that there should be a clock,elapsed time,timer & stopwatch function. This is a very attractive player for runners,bikers,fitness people and it would probably be a no-brainer sell if time/timer functions were added to cater to this large group of potential buyers.
I think we might see less posts about losing the clip part of the clip+, that thing looks serious
For the record – 4gb for $49 is an insult in both size and price. There’d better be a 16gb version of this – with flash memory so cheap now, I refuse on principle to buy any more 8gb (or smaller) players…
C’mon Sansa, come correct and do right by your customers…
The real insult is the $49 2GB Clip price in stores across the country even now. And with a card slot, and redesigned clip, folder nav. and track info, I think the price is quite fair.  For $100 you could have a 20GB player, if you added a 16GB micrsdhc. That is a screaming good deal.
As Marvin_Martian just pointed out you can effectively get a 20GB Clip+ for $100 with the addition of a 16GB microSDHC card. I just priced the cards at Amazon and they have a 16GB Kingston Technology microSDHC card for $49.99 with free shipping (this comes with an SD card adapter as well).
Just to keep things in perspective, I bought my first Clip, a 2GB model, for $35 on Black Friday 2007. That’s $17.50 per GB. I bought my second Clip, a 4GB model, for $35 on Black Friday 2008. That’s $8.75 per GB. Now, I can get a 4GB Clip+ for $50 and a 16GB microSDHC card to go with it for $50 for a total of 20GB for $100. That’s $5.00 per GB. And needless to say, the Clip+ is infinitely expandable with the purchase of more microSD cards. As you add more cards, the average cost per GB continues to go down. And if I wanted to wait until Black Friday 2009, I’m sure the prices of both the Clip+ and 16GB microSDHC cards will be less.
I hate sounding like a fanboy, but I think Sansa did well with the Clip+. Compare the Clip+ feature-for-feature, including sound quality, with anything else out there in this price/capacity range, and I think we know who will come out on top. :slight_smile:
No, it’s really not.
Sandisk sells 16gb flash memory packaged for retail use for less than $30retail price , so you’d have to think their manufacturing cost is less than half that. The retail spread between 4gb and 16gb is just $20, so for (really less than) $69 Sansa could retail a 16gb Clip+. Add an 8gb microsd card for less than $15and you have 24gb player for less than $85.
Add a 16gb card and you’d have a 32gb player for $120. Now that’s a screaming good deal…
…but Sansa knows that buyers of 16gb players may not buy any cards, hence the small capacity players that almost require a card purchase…
Hello everybody,
I am wondering if they have fixed the “pitch problem”, on the Clip Plus.
On the original ver.1&2 Clips, an Mp3 encoded at a 44.1 kHz sample rate (default setting for most software) will play back at a slower speed/lower pitch when compared to the original recording.
This is a real problem for anyone who likes to play along with the music on the clip, as it will be out of tune with your instrument.
The problem affects Mp3 encoded at 44.1 kHz sample rate (the default sample rate for all CDs and most Mp3).
If you are willing to encode your Mp3 at 48 Khz sample rate, when you rip your CDs, the pitch/time problem is not noticeable.
The fact that they have not fixed the original clip with a firmware update yet, is unacceptable.
In light of this, I would like to see the results of “pitch” tests for all playback formats with all sample rates, on the Clip Plus to see if there are any remaining (or new) pitch problems or other sound quality issues, that folks would want to know abut before they buy a new Clip.
Another question I have about the new Clip Plus, is regarding playback of non Mp3 files (FLAC, OGG Vorbis, etc.)
On the original Clips, playback of these formats causes a noticeable reduction in battery time.
 Is this also true for the Clip Plus?
One of the great things about the original Clip is its excellent sound quality(if you ignore the pitch problem).
I’m wondering if, like the first clip, the Clip Plus hardware/firmware is optimized for playback of Mp3.
If so, I’m also wondering if there is any compromise/reduction of audio quality, when playing back non Mp3 files, as compared to Mp3.
I know that the built in mic is mostly intended for recording voice memos and lectures, and it works great for that.
I really like that feature.
Considering that they already invested in the hardware/software to allow the Clip to record audio, why only mono, why not record stereo? It would be great for recording band/choir practice or music at a local club or concert.
As it is now, it makes pretty good mono recordings of me playing my acoustic guitar into it.
Any changes to the center button function or other interface differences/options, besides folder view?
Link to, or scan of Clip Plus owners manual?
Can the Clip Plus be “Bricked Up” like the original?
What is the firmware version?
Wonder if it would work on an old Clip? (probably not)
Thanks much if you can answer any or all of these questions.
The most important to me, regards the pitch problem.
Best of luck to Sansa and there customers with the new Clip Plus Player.
Shame on Sansa for not fixing the pitch problem in the original Clip yet…
 I will not purchase or recommend a new Sansa product until they address this defect on the old one.
Happy Trails…
Wavy
Or you could buy a used 4GB Sansa Connect from amazon.com for $25, add in the 16GB card, get a player that also does video, and get free Launchcast streaming radio in the bargain.
:manhappy:
(Sorry, I’m a Sansa Connect fanboy.)
