the SSD needs to be unpartitioned, the software will partition the SSD itself. if your drive is unpartitioned can you post screen shots of the error as well as the disk managment window?
install the sandisk SSD tool kit and see if it sees the SSD. if so post the SMART attributes.
what is the disk configuration of the PC where you are trying to use the expresscache software. also if you can post screen shots of the disk management and device manager windows that will be helpful as well.
what SATA driver are you using? if you are using intel RST 11.6 they changed how the drive ID is displayed and expresscache does not see it as a readycache device. if this is the case you will need to roll back to intel RST 11.2
If Intel develops new drivers, this is not to fill the servers. They are there to be used.
When is a version of Sandisk SSD supporting ReadyCache Drivers
When is a version that supports Windows 8?
Thank you for the answer
Mine still doesn’t work on either 11.1/.2/.6 drivers. Albeit, the connection is SATA II and part of my laptop set up.
PLEASE HELP ME. The laptop actually recognized the drive once and let the ReadyCache software install. After a reboot though, the Drive went back to being recognized as the “Sandisk Milpitas SSD” instead of the serial number. In Intel SRT, refreshing the devices will cause the SD ReadyCache to be forgotten and removed until the next reboot.
Granted, my SD ReadyCache is mounted in my Optical Disk Drive Caddy and connected via SATAII while I boot from my 640gb HDD. I’m stuck right now.
I’m having the same issue. One thing to note, on device manager this is listed as SCSII instead of “SanDisk SDSSDRC032G ATA Device”. Also, everyone on this thread seems to have this identified differently in device manager than what the FAQ states it should be in the troubleshooting section:
Could this be not working because of an old motherboard which treats SATA as SCSII or something other than ATA?
if you have the Intel RST 11.6 sata driver it changes the way the drive is identified and removes the 032G from the identifier. This prevents EC from installing. You will need to roll back to Intel RST 11.2. This is suppose to be fixed in the next EC software update. We have not seen a date for release.
this is probably due to the bay you have the RC drive connected. What driver is being used? If you notice the box says for desktop computers. You may not be able to make this work with your configuration.
Unfortunately my motherboard is AMD and uses a non-Intel SATA controller (thus the SCSII designation for anything plugged into my SATA ports)… I’m currently using the drive w/ Win7 ReadyBoost and will have to wait to see if this ever works as advertised…
can you post a screen shot of device manager under disk drives so we can see how the RC SSD is identified? Currently if it is not identified as SDSSDRC032G it will not be seen as a RC device.
Also we will need to know what SATA driver you are using.
