I got the Fuze this morning. I can’t figure out how to get songs on it. Can someone help? There was a cd that came with it, but I can’t figure out how to install anything (if anything needs to be installed). Can someone please help?
Ok First unless you like Rhapsody take the cd that came with and set it off to the side. I assume you are on a windows based machine? If so, plugin the fuze, Open windows media player click on the sync tab and when it recognizes the fuze Click and drag your music from your library to the sync area (This is the column under the device(Left Side). When you are ready press sync at the bottom of that column. It should be that simple. There are other methods but this is what I have found easiest to get started
Message Edited by Conversionbox on 12-25-2008 03:00 PM
And of course, when all else fails . . . read the User’s Guide. ![]()
Tapeworm, I am SO glad you posted that! WHERE did you find that user’s guide? My Sansa Fuze didn’t come with one, and I couldn’t find it on the website.
(Would write more, but can’t wait to print it out and study it!)
Right there at the top of the Fuze board, titled General Information (1st post) right where it’s always been so it can be easily found. ![]()
Sheesh. (Where’s the emoticon with the rolling eyes?
) I kept searching for “Fuze instructions” and coming up with zilch!! I should have searched for “Fuze user’s manual.”
