Is their a way to recover a damaged file on an SD Card? It shows there are 46 GB for the file, I just can’t read it on my MacbookPro. Thank you in advance
I filmed a couple other files in progression but this one is damaged.
Did you have a backup? Have you tried data recovery programs? If not, maybe you can search on Google to find a recovery program to recover the damaged file.
Before using any software, I would recommend making a backup of your SD card just in case something goes wrong during the recovery process. Once you’ve made a backup, you can try using a recovery program to restore your damaged file.
