I have a Kingston micro SD of 512 MB.
I have a Kingston micro SD of 512 MB and it gives me problems…I know I should upgrade to a higher capacity card but I think this one shouldn’t give me any problems. I had to reset the whole thing before being able to use it normally with the built in memory. when I have the micro sd in the 1 GB device it will get stuck and wouln’t work at all untill I take it off and then wait a while.
Any hints on this?
Help please.
Any hints on this?
Help please.
You should be ok with using the Kingstom card. The attached thread appears to say that Kingstom up to 2 gB will work with the Express.
http://forums.sandisk.com/sansa/board/message?board.id=express&thread.id=1130
Update your firmware to the latest. Format your card to FAT 32.
