Hello everyone!
today i formated my Clip and wrongfully i totaly deleted my frimware…
and the Windows Vista dont Recgonize it now…
when i try to access it … it says… " Please Format the Device"???
HELP!
Hello everyone!
HELP!
Yes i did.
i turn off the device and then Hold the center button till i plug it in to the PC and it turn on and i realease the button…
but still it wont work ![]()
Help PLEASE!!!
When im turning it up it says :“Not Enough Space for music DB, Please Free 30MB”
and then it turned off
Dont forget to slide the lock switch to the hold position then hold the center button while connecting.
i did… maybe it is because i got Windows Vista?
And my Device used to be Hebrew Interfaced
Format the device from Vista.
i did
Howdy all you music lovers,
I fixed my Ver.1 2 Gig Clip by doing the following computer based format/partition/firmware install…
(my original format operation did not work until I set Partition type to MBR, see note below)
On a PC:
and then it turns itself off
With an Apple Intel MacBook laptop running OS 10.5.6, I was able to restore my Clip to normal with the Disk Utility and the settings below.
Formatting will only delete/erase content put on by you, the user. It will not erase the firmware or any needed operating files, so it is safe. You will have to reload all of your music, etc. tho, it shouldn’t take long.
Hope this helps some of you out there who have “Bricked Up” Clips, get back in the mix.
Happy Trails
