I can't shuffle a playlist.
Is there any way I can shuffle an m3u playlist I made? I don’t use the GoList feature. I can shuffle albums and artists and ALL my songs on the mp3 player, but not made playlists. Is this just not a feature? If so I should not have bought this player.
These 2 methods work on my Clip Sport (non-plus version).
Settings -> Music Options -> Shuffle = On
     OR
Music Menu -> Playlists -> Select a playlist -> select any song to play.  Then, while the song is playing, press the Option menu button (below the large oval Select button).   Then select Shuffle = On.
The Shuffle selection will remain active during subsequent music playback from the Music menu, Folder menu amd Card menu.
      OR
Music Menu -> Playlists -> select a playlist -> select any song to play.  Then, while the song is playing, press the Option menu button (below the large oval Select button).   Then select Shuffle = On.
The Shuffle selection will remain active during subsequent music playback from the Music menu, Folder menu and Card menu.
