@blackdog_sansa wrote:
WMP is a real PITA
Synching is a real PITA
Together they are …a bigger PITA
I learned this after about three weeks of extreme frustration when I first started.
No more WMP
No more playlists
No more synching
MSC and drag/drop just like you’re going to a USB flash drive.
I have a large music library back on the PC and there’s no way I would want to synch it.
Microsoft has cause so many headaches with all their garbage.
One other thing I’d advise: Every so often just backup your entire Fuze to the PC, music, videos and all. Just make a SansaFuzeBackup folder and copy the entire thing. Do this once a month or so. Worst case if you crash or have to re-format…everything is right there in one Copy maneuver.
As far as my Fuze goes…
"No more WMP
No more playlists
No more synching
MSC and drag/drop just like you’re going to a USB flash drive."
Completely agree on those points…If I must make a list, I use the Go List, and drag and drop ensures my album art, which is supplied by WMP to my music folders , actually makes it to my Fuze. ![]()
Now as far as my 8GB Clip…I still add and remove music from it with WMP(with the exception of any Ogg Vorbis or FLAC that I might use) , in MSC mode, because it’s simple, and album art doesn’t apply, and it’s nice to see just how much room is left when you’re deciding what to add to it. :wink:
