Please, let me know whether there is a way for me to rescue USB flash drive data successfully! Last weekends, my little son had formatted my USB drive anyhow. But, I really didn’t know that till I found it yesterday. Now, all my stored videos, images and files were gone. Could you give me some suggestions to get them all back?
What exactly did your little son format the drive for? And what did he do with the drive after he formatted it? If he wrote to it he could have written over your files.
ALWAYS have backups of files you don’t want to loose. On your hard drive, on a CD/DVD, on another flash drive.
Have you saved anything new on this formatted USB flash drive since then?
Nowadays, the formatting process, especially the quick formatting process, often will not erase everything on the drive immediately. As long as the stored data is not overwritten by anything else, it will be reserved there forever. Therefore, you’ve better take care not to write anything new on this drive.
And then, in order to rescue your data back as soon as possible, you need a formatted USB flash drive data recovery tool like 4Card Recovery, Recuva and iCare Data Recovery Free, etc.
No matter which one you choose to use, you’d better act carefully all the time.
Note: Always be careful about your important data and never format a USB drive or memory card without a data backup in the future.
4Card Recovery is not free. The other apps are. I suspect Hay4534den is trying to up his (company’s) app on search engines hoping some unsuspecting visitor will click on his link. His website use to have a photo showing the registration prompt when attempting to recover files but it’s been removed. I think registration is $89.99.
Recuva is wroth trying, a freeware and can recover data. If you cannot completely with it, try another software called remo recover, it can recover photos, music, images, etc. from USB flash drive, but if you store important office file like word doc or excel spreadsheet, you may want to use office regenerator to completely recover deleted xls/xlsx spreadsheetor doc/docx file.
It could be way better to ask a specialist to recover your data although the service is expensive I got my data recovered for less than $300 by www.295datarecovery.com
Formatted USB flash drive data is not so difficult to rescue, as long as you take the right steps:
1). Stop using this USB drive in case of overwriting.
2). Plunge this drive to your computer and check whether all your lost files are recoverable. What you need is to download a USB flash drive data recovery tool for your lost data, like Recuva, iCare Data Recovery Free and Power Data Recovery, etc.
3). Save and back up all restored files on another USB flash drive.
Note : No matter what happens, you should always remember to back upall drive data on different drives well.
I had similar problems before. I formatted the hard drive by mistake. And I tried many solutions to recover them. It’ not difficult to recover the files if you didn’t overwrite new data to it.
Maybe you can try Bitwar Data Recovery , which helped merestore my lost data from the hard drive. It also provides 30-days free data recovery. You can try it, I hope it will also help you!
It’ not difficult to recover the files if you didn’t overwrite new data to it. Maybe you can try Bitwar Data Recovery, which helped me restore my lost data from the hard drive. It also provides 30-days free data recovery. You can try it, I hope it will also help you!
First of all, some Sandisk flash drives support TRIM, which means data recovery will be very difficult or even impossible. This is true even if you use professional data recovery software.
No need to freak out. Before attempt any recovery, you should check out all your backup drives. If you have backups, you can recover formatted USB drive without spend a penny. Alternative, you can pick a data recovery service with a high success rate. You should expect to pay around US$400-600.
Some misleading articles suggest trying to use CHKDSK to repair the drive. Do not do this as it could lead to further damage.
If the USB drive was accidentally formatted, there’s still a good chance of recovering the data, but this depends on a few key factors.
How was the USB drive formatted? If it was formatted using the quick format option on a Windows computer, the data might still be recoverable, as this process only removes the file system index without overwriting the old data.
Have you used the USB drive since formatting? If you’ve continued using the USB drive after formatting — for example, by storing files or running disk cleanup utilities — some of the old data may have been overwritten, reducing the chances of recovery.
First, check if you have a backup. If not, you’ll need to use data recovery software to retrieve deleted files from the formatted drive. However, remember to store the recovered files in a different location, not back onto the original USB drive. [ Related how-to blog: Best USB Recovery Software to Save Data from USB Flash Drive ]
