I have just received used HTC HD2 from ebay. It has original micro sd card 16gb. But the HTC does not whant to recognize this card. Every time when I insert it, the device ask me format it. And if I agree it shows a message after a second that format was successful but I can see this card in phone.
I tried to read it using car reader on my pc. Some readers cannot see this card, but some can see and ask format it, when the format dialog is appeared is shows that card has only 31mb of storage and I can format it in fat or ntfs. But if I click format I’ll see the error message. Also I try to insert card into Nokia N96. It also can see only 31bm can format it and I can write something but cannot read. If I turn off the phone and turn on it again, or release insert the card the phone asks me format it again.
No one utill like sd formater or hp cannot format it. Anybody knows what to do?
PS
I found the deleted topic on this site in google archive. Someone has the same problem as me. Here the description of the problem
My PC is XP SP3 and use Windows Media Player 11 to sync my Fuze. The Fuzeis 4G and is firmware version 02.02.26A. I recently purchased a Polaroid brand (didn’t have sandisk brand) 16gb micro SDHC for it. When I put the card in my Fuze didn’t recognize it until I upgraded the firmware to the version listed above. The Fuze will only format the card to a 2gb capacity. I went ahead and did it anyway hoping it would show 16gb instead of 2gb…stupid I know. Anyway, afterwards I attempted to re-format the card on my computer using one of those flash drive style readers. When the format dialog came up my only options were “FAT” instead of “FAT32” and a disk size of 30mb. I cancelled it and now the computer will not recognize the card unless I unplug and replug the drive…doesn’t matter whether or not I removed and re-inserted the card.
How do I get the card set up to work with my Fuze?
Do I need to get a “proper” card reader in order to format SDHC cards?
