i can’t format my pendrive. it’s saying that it’s write protected. at first when i brought that pendrive it was working well and good, But after some days it suddenly sarted saying it’s write protected it’s beacause of the viruse. But now i am un able to remove it. If i try to then it will say that it’s write protected. How to fix this?
The only fix is to return it for a replacement. Either to where you bought it or directly to SanDisk.
http://kb.sandisk.com/app/answers/detail/a_id/5232/~/return-material-authorization-(rma)-process
Copy whatever files on it you want to save to your hard drive before returning it.
Hi ,
This is simple error. so dont worry. follow this then you can Format your Drive
Hi, use “ diskpart ” command.
- Go to command promat
2. “ diskpart ” enter. - list disk " enter
- selet disk.
- clean
source - How to Remove “Write Protection” by Using Command Prompt 1
